Fuel supply: UK suspends competition law
Bin Man:
Do the maths.
The same amount of cars running the same average mileage at the same mpg with the same fuel tank capacity as before.It makes no difference to the depletion rate whether they fill up 5x more often with 5x less each fill.The panic buying excuse is bs.Supplies are being deliberately held back for obvious reasons Boris wants to flog his unnaffordable EV green revolution to a rightly reluctant public.
Domestic gas supplies next.
I went out last night at 2am loads of usual 24 hour garages closed, empty roads including M25, no one around …and not a tanker anywhere to be seen and we know they work nights.Then phoned around and found one garage open no supply issues no limits take as much as you like I was the only person there among loads of open useable pumps so around £50 of 99 E5 in the tank all good.
Probably going out tonight this time with a 1 gallon can to then put in my relative’s dry motor who hasn’t been able to use it since last week then I’ll drive it back to same garage to fill it.Hopefully all good but haven’t phoned to check the stocks there yet.
So amounts drawn to fill the same car tanks as before are irrelevant in this government sanctioned scam.
You have completely missed my point, some people cannot afford to put £40 in their car in a month, my next door neighbour is a single parent she works part time where there is no public transport, she has an old diesel car and only uses it fot work I bet she doest put more than £20 in her car each month your scheme would punish her and all like her.
Read it closely it was meant as devil’s advocate to appease the ‘panic buying’ believers.
So regardless of however she fills it and when and how often it’s the same amount she’s using in the same car and the same fuel tank.
What’s changed with the garage depletion rate …nothing, zilch.
Bearing in mind the admission that garage storage tanks are never more than 45% full and now for some reason they are never more than 20% full.
Which can only mean that the tanker delivery is always around 55% short of the garage tank’s capacity or it’s always 55% less frequent than needed.
Or a combination of both.
So now the government has increased that short delivery/frequency figure by 25%.
That would explain why 24 hour garages are all closed and not a tanker to be seen anywhere at night nor much in the day and when they do deliver the delivery is always deliberately far less than the garage tanks can/should hold.
At which point Al Gore sends in his 600 mil for Octopus to start getting its EV charging network up and running.
