beattun:
can someone enlighten me as to what / where this trailer brake you speak of is?
To start from the beginning, the U.K. Construction and Use Regs prohibit the parking of a trailer ‘on air’. Sensible really, as when the air pressure depletes, the brakes disengage.
This was the case until the late 70’s, 80’s (ish), when Spring Brakes became the norm.
You no doubt understand that a Spring Brake consists of two air chambers, an actuator rod, and, as the name suggets, a bloody great spring.
In normal operating conditions, the Spring, which would otherwise act on the diaphram and actuator rod thereby applying the brake, is held ‘off’ by a certain amount of air pressure. Typically, about 6 bar.
In normal operating conditions, when applying the brakes, an imbalance of pressure in the two chambers allows the actuator rod to extend, thereby applying the brakes.
When uncoupling, the normal action of removing the air line allows, (and this is where I get confused as to the difference, and will gladly be corrected) the air ‘holding off’’ the Spring to be depleted, thereby applying the brake. However, if there were to be a constriction or a defective component that prevented the air exhausting, the wheel would remain ‘unbraked’.
The ‘Trailer Brake’, essentially an Air Valve, uses the reservoir of air in the trailer tank to ‘imbalance’ any residual air that is holding off the Spring, and thereby applies the brake.
The difference between ‘removing the red line’ and ‘applying the trailer brake’ has been explained elsewhere on these forums, but I am a loss to find it.
