suzi boom
jon
suzi boom
jon
jonboy:
suzi boom
jon
Thats the best type of suzie boom, With a non coiled section at the bottom, which stops them getting covererd in grease and some coils at the top for strectch if needed,
The ones that get covered are when a suzie boom gets fitted and normal suzies are attached to the end, Then you have a huge mass of tangled lines, ![]()
So when I have to change a suzie I get plastered in grease
The only one problem with suzie booms is when it gets bent down and then catches on the catwalk and does not move!!!
Thanks for the pic jon
I was just looking at the height of jon’s trailer and
was wondering is the 4.000m the trailers height
which would be Just over 13ft I think and then you
add on 1250mm which is the height of the truck
and then you have the truck + trailers height. Also
isn’t 1250mm the normal height of trucks ![]()
convoy:
Thanks for the pic jon.
overall height of 13’2". and the 1250m depends on what tyres are fitted
jon
Cheers jon
someone told me that
most drivers take a tape measure
with them and measure the height
if not sure
