Saviem:
pete 359:
Saviem:
Evening all, good ■■■■■■■ stuff coming through! cav551, excellent post on the 220s, but the engine you refer to used by ■■■■■■■ in their marketing, was a 180, in an LV ERF, (was it F, 68 reg)? that was operated by Plants at Gnosall, Nr Stafford. Cracking engine those 180s, I always thought them more “driveable” than the 205, (but not the 220).I do not know if “my claim to fame” is truly such, but I always wondered if I was the only person in the UK to have run a KTA 18litre in a tractor unit? Back in 94 I imported a Marmon conventional, (the rare breed from Texas). Bl… ugly thing, … but wow was she impressive! KTA,@600hp, (and like lots of these show and go trucks came with the dyno sheets)! 15speed double overdrive, and a six speed spicer behind that! No, truly I could not change through every gear, who on earth specs transmissions like this, only does it for one purpose, to achieve a set of gears that provide the optimum performance for their needs, and the fact that you end up with a myriad of unusable ratios is purely incidental! Tandem SQHDs on newway air, 90in Double Eagle, odly she ran on aluminium 20in Budds,80%, and no caps. Painted in Misted Imron, (a fading green), so many gauges that you just got worried if a needle moved! But the heart, The KTA, what can one say, just excessive in every way, just the sight of it when you tipped the bonnet, the rumble, the whistle, gears, you do`nt need gears, she had come from an Owner operator from Oklahoma, via an old friend in Kansas city, and had been contracted to Bekins. Why on earth the man specified a KTA could only be ego, and lots of it! But what a wonderful machine, and what a fantastic engine, (despite having exceeded 1000000miles, as documented). And she still lives in Italy with the proud owner who purchased her from me!
[ZB], interesting point, and often overlooked, about the way manufacturers declared their engines power outputs. Apples and Pears comes to mind! Somewhere in a filing cabinet I have an excellent guide published by Unic, (Iveco), regarding the published ratings of all engines available in the French lorry market, like for like. A very useful document, (and very well thumbed)! One thing Iveco,as an organisation excell at, clear documentation, and product comparison. But they do`nt make inline 6cylinders like what ■■■■■■■ did! Cheerio for now.
Hi saviem,
My mate rob Wilson owns this mk2 contractor,seen here in Abergavenny steam fair may2012.rob’s mk2 is powered by an American k series 18 litre ■■■■■■■ diesel.as originally fitted by scammell.an interesting spec.on the marmon that you imported.
Regards Andrew.Evening all, hello Andrew, I did not know that Scammel fitted the K series a a straight option. That Contractor is one hell of a motor to own, I presume she has a semi auto box? Lucky man!
A lot of the later French Willeme TGs, as built by Perez et Raimond, the French Detroit importer, later had the Detroits taken out, and replaced by KTs. One such, still operated and owned by Phillipe Brame, as either a ballast locomotive, or as a 120tonne 5th wheel tractor, is powered by a KTA, with a Clark auto box. Transports Zucconi had a KTA regularly working at 300tonnes, (6x4), and Transports Scalex re engined an original Willeme TG Detroit with a KTA, 8x8 at 700tonnes plus!! Some lorries! "Our " Berliet TBO, was physically similar size to the Contractor, but never, ever the match of Louis Willemes designs!! (even when retro fitted with a KTA, surely the worlds most favoured retro fit "big hitter " engine of its time),
Yes,that Marmon was an interesting, (if little confusing), spec. Most of the US iron that I imported was ■■■■■■■ powered, (I always felt “safe” with Mr ■■■■■■■■■■ but I did bring in some CATV8s, and (a big mistake… some “green leakers”), incredible noise,and with Allison Autos, so fast as to be unbelievable), but hard to sell!!
The only "double boxes " that I imported were the Marmon, two W900s, and a Pete 362, withthe longest wheelbase I have ever seen, covered by an enormous “Naughhyde” filled double Eagle, ( a masterclass in how to waste space)!! Most were RTOO. or RTO 13, or 15speed, and the second box was universaly a Spicer 6speed. Now the 362, (more blind spots than any other vehicle ever), had a 10speed Spicer, with a 6speed Spicer behind, and was actually the nicest one to drive of the lot!!! She found a home in sunny Spain, (and what an enjoyable “delivery drive” that was)!!
But you know when we look back, the biggest break through for ■■■■■■■ was the “Big Cam E290”, hi torque rise 14litre. But what consternation that engine caused in the UK market. It would not fit most chassis! Foden, ERF, had to totally redesign their front axle to take the physically larger, (heavier), engine. The only UK assembler that could accomodate the E290, was Seddon Atkinson.
But the physical dimensions were not the only problem…no one had an axle “tall enough” to accomodate 60mph @1700rpm!! Only the US manufacturers!!!( as an aside , was this the catalyst that turned Foden towards propriotory components, axles, gearboxes, et al)■■ Exactly the same situation pertained with clutches, and their torque capacity!! Could it be said that the E290 was the catalyst for US inspired drivelines in UK assembled, (manufactured) lorries■■? A point to ponder upon, and I shall ponder with the aid of several large glasses of Bollinger, Bon Nuit, mes braves, Cheerio for now.
hi saviem,
to be honest,i wasn’t aware of the k series fitted in contractor’s,which some might say,shows how little i know .i am sure rob told me she had an allison box.i take your point about the double eagle and it’s wasted space,when i imported my 359 i was astonished at the strange sleeper layout.back to the title of this thread,i also totally agree with you about the e290,i was only a kid at the time,but they really were revolutionary back then.i am pretty sure? that one of the first transcontinental’s sold in south wales had a k series ■■■■■■■ in her.there’s a picture in the book about them,glyn s. john transport ran her,an n reg. i think?keep up the info. and memories saviem,i know i’m not the only one that shares your opinions
regards andrew.
