Lucy:
Ditto running with your empty 20ft still fixed in tip position back to the docks. Not stable, and won’t do the trailer any good at all, never mind your underpants!
Please provide evidence to back up that claim. Personally I think you’re talking ■■■■■■ (I’m referring to running with tri-axle slider in the closed up position with axle 1 raised).
smee unless you go to nettos aldis lidl tip yourself takes longer for them to open the bay doors than it does for you to tip then they check them etc etc but if your hourly paid great not so if salaried
paulduncan:
Rob… Lucy has forgotten more about containers than you’ll ever know…
Just another Rob K wind up and load of Bull [zb]…
Shows how little you know about my working life then. How about you keep your beak out unless you can prove or disprove the argument? Yep, sounds like a good idea to me!
I was enjoying the topic until he decided to take a pop at someone… Again… and by the way I have some experience with containers… as that’s what I run … all week long…
if you open the container doors dont stand behind them
open the door and walk round with it so anything that falls out dosent land on you.
if anything does fall out dont worry about it you didnt load it.
i once won an arguement at nettos at south emsall…
pulled onto the bay they cut the seal and i pulled off to open the doors. when i open the doors a load of stuff fell out not my problem so i told the lad on the bay who was going to tip the box that he had better come down and move it all.
we then had the arguement whos going to shift it. he wasnt allowered in the yard and i couldnt give a ■■■■ cos whats in the box im not allowered to touch so it turns out stalemate neither of us are insured. problem sorted jumped in the cab and stuck in reverse and reversed over it all.
next thing manger is down having alook matey on the bay gets a bollocking for not shifting the boxes and i get the plesure of driving over thier goods again while matey jumps down and shoves the boxes on the bay.
paulduncan:
paulduncan:
paulduncan:
Zzzzzzzzz…snnrrrr…zzzzzzzzzzz…snnrrrrr…zzzzzz !!!
we keeping you awake Mike
No mate, i’m just about to type up a proper container drivers diary, here goes !!!
Make sure that your twistlocks are in the correct position before the crane drops the container on. Asking for the crane to come back and lift up the box because one of your locks wasn’t quite aligned and is now jammed by the full weight of the container can make you rather unpopular
Make sure that your twistlocks are all open before they come to lift the container off. The only container port I’ve been to, you have to undo your twistlocks before you drive up to the empty container “forklift” guy - the moment you stop in front of him, he grabs the container off straight away, so if you haven’t already disconnected the twistlocks, your trailer is going with it…
Cheers Mr F
Didn’t know you had done containers you have been busy
