bluenose:
Diesel Dave is there a legal minimum spill kit for a curtain sided trailer doing various ADR classes (not 1 & 7), …
Hi bluenose,
There is no actual requirement for a spill-kit as such, but a vehicle may carry a spill-kit.
When you carry Classes 3, 4.1, 4.3, 8 or 9 AND the load exceeds the relevant ADR Transport Category ‘freebie’ limit ( = full ADR applies,) then you will need at least:
- A shovel
- A drain seal
- A collecting container
This is written near the bottom of page #4 of your Instructions In Writing (IIW,) but watch out for the little letter “c,” because that tells you (right at the very bottom) which UN Classes trigger the requirement.
bluenose:
also is the fire extinguisher 12kg (1 at least 6kg)?
When a vehicle carries dangerous goods (but not in Limited or Excepted Quantities) an ADR compliant dry powder fire extinguisher of at least 2kg must be carried. This applies to all vehicles.
Once a vehicle carries in excess of the relevant ADR transport category load limit ( = when full ADR applies) then the vehicle must carry a second fire extinguisher, primarily for a tyre or brake fire.
The required size for the second fire extinguisher depends on the authorised GVW of the vehicle…
Permitted G.V.W. less than 3,500 kgs needs ANOTHER 2kg extinguisher as above, making a total of 4kgs.
Permitted G.V.W. between 3,500kgs and less than 7,500kgs needs ANOTHER 6kg extinguisher making a total of 8kgs
Permitted G.V.W over 7,500kgs ie ANY LGV needs ANOTHER 10kg extinguisher making a total of 12kgs
Once the vehicle is an LGV, it doesn’t matter whether it’s a rigid, wag and drag or an artic.
I covered the requirements for fire extinguishers in a bit more depth and with a couple of pics here:
Even though the linked post looks like an old post, the info is still correct.
