Here is the page from manual that the VOSA testers use.
Skeletal trailers with containers do no need top lamps. Obviously
Nor do demountables, or tippers and tankers
Big Joe:
fingermissing:
What happens if you pull a container they donât have top marker lights on them. You then
only have 4 marker lights and 2 headlights.
Why do they have lights on top of trailers any waySkellys have two on each side at the bottom if they were built after 1999, as do low loaders and flats.
Which in fact is the top on those sort of trailers.
Coffeeholic:
Big Joe:
fingermissing:
fingermissing:
ncooper:
fingermissing:
Why do they have lights on top of trailers any waySince you ask, a container isnât a trailer, its a load.
Second question, so you can see where they are in the dark.
Third question, that you didnât ask, cab top lights are to show that itâs a big vehicle
even when itâs too dark to see the rest of it.Regards,
NickIve learned something new today about a container.
Itâs why many years ago before they changed the road tax system and it was done on number of axles you were supposed to drop the axle when running with an empty container as it was the load.
Big Joe:
fingermissing:
âOld-schoolâ tilts used to (still do?) have 2x marker lamps each side, as there is nothing to fix them to at the âtopâ
As I recall, cab-top marker lamps were made compulsory circa 1983 (âYâ to âAâ reg)
How comes the âtopâ markers on a topline scanny are on the visor and not the roof?
Our 3 brand new mega trailers donât have top markers front or back.
Coffeeholic:
Big Joe:
fingermissing:
or the bottom
, but the two per side at the bottom, or could be top
plus two cab top marker lights = six markers
, hang onâŚwhere did that green light come fromâŚ
âŚNURSE
