mike68:
We had a trial vehicle some years back that had the cruise control disabled to see if this conserved fuel, the theory being that the cruise control when used to reach a cruising speed used more fuel.
It is what it says it is a cruise control, when used to reach a desired speed the throttle is fully opened when not used and the driver reaches the desired speed without using full throttle fuel is saved.
Try only using it when cruising and using economy mode (if fitted) economy mode derates the engine power slightly when cruising and revertes back to full power when required hills for example or when the driver presses the accelerator.
Well Mike i tried a little experiment today along the lines of your post.
@ 43.5 tons in 12th with cruise engaged at 53 but the lorry climbing a long long hill @ 50mph, the instant readout is a steady 3.9mpg, thats pretty well average for most 44 tonners i would suggest in top gear pulling hard.
Now i dropped her out of cruise and with the angle of the incline unchanged, and maintaining the same speed 50mph, i could bring the throttle back from full to roughly 2/3rds and still maintain the same rate of climb, and the consumption steady @ 4.5mpg, dropped her in and out of cruise a couple of times on the same long drag, same result every time.
I did this experiment several times today and the result was the same every time.
If i kept my foot hard down, same as cruise does automatically then i suspect the 3.9mpg figure would have been unchanged, but what was interesting was how the rate of climb didn’t change yet the fuel being used dropped a fair amount, that 3.9 to 4.5 difference if duplicated over a day’s running could see a big difference in overall mpg.
This is real life figures, so it makes one wonder with the cost of these telematics systems, plus people employed to monitor such things, have these companies buying into telematics and not being open minded about techniques been hoodwinked?
I’m not suggesting my little experiment is the default to go by, far from it, but if others interested in this might like trying similar tests we might have some interesting comparisons.
I’ve never been one for using cruise for acceleration, and i won’t be altering.
Thanks for posting that Mike, it’s been an eye opener.
