ERF:
All I am asking is… GIVE US SOME BMEP FIGURES to compare!!
Rolls 220 12.1 litres 610 lb/ft = 50.4 lb/ft per litre x 2.464 = 124 psi.
AEC 800 13.1 litres 580 - 638 lb/ft = 44.2 - 48.7 lb/ft per litre x 2.464 = 109 - 120 psi.
So there we have it 13.1 litres and 8 cylinders with at best worse specific torque of less than 50 lb/ft per litre than 12.1 litres and 6 cylinders.As I said might as well have condemned it at that point sooner rather than later.
While the Rolls 305 at 70 lb/ft per litre showed a similar advantage over the TL12’s less than 65 lb/ft per litre.Which again suggests that more leverage beats more piston area…
Thank you CF!.
At last!.
Although quite why have you chosen to compare the AV800 with the Rolls 220 I don’t know.
The AV740 engine makes a better comparison because both engines have the same bore size, both have the same 12.1 litre cubic capacity, and both produce their maximum torque at the same RPM - 1400, thus making the only difference their basic architecture (as you like to call it) - the ‘all important stroke’!.
The first thing we need to do is to make sure we’re all singing rom the same sheet, ie all figures quoted are produced to the same standard. In the case of AEC, playing by the rules as ever, all figures were quoted to BSAU 141:1967 (Atmospheric pressure 760mm, Inlet air temperature 20 dec C…etc). Just at this exact moment I can’t find the figures for the Rolls 220 where they have been expressly quoted to this standard, but I will try when I have more time later so that we can complete our comparison.
The whole point of using BMEP figures is that they remove cubic capacity from the comparison.
This makes it possible to realistically compare the ‘work’ ability of engines produced with different overall capacities, which is why I can’t quite understand why you are re-introducing capacities, and different ones at that, into your thinking above.
With BMEP we can accurately asses the ability of an engine design to inhale air, compress it, inject fuel, burn it and get usable power from it.
Without wishing to get into an argument on the why’s, the formula used in the engine development profession to calculate BMEP runs along these lines (sorry it is a scan of a sheet issued to Perkins students, but I’m not clever enough to get the characters on my keyboard)…
You will note that no torque figure is introduced into the actual equation, the torque being used to calculate the Brake Power.
Using this formula, the AEC AV740 engine produces a BMEP of 115.1 psi - so actually not wildly different from your figures.
For a direct BSAU 141:1967 comparison, the Perkins V8 in both 510 and 540 form produce 112psi.
The 130mm bore AEC AV691 produces a BMEP of between 115 and 116 psi.
When we have confirmed the Rolls 220 figures to the standard, we will compare that too.
