Additional lighting
Acorn:
Alas you’ve picked a poor example who have mis-quoted the regulations. Static blue lamps are not prohibited to the front. A static blue lamp does not resemble a WARNING beacon or SPECIAL warning beacon (Reg 16).
Then you can fit some over 4200 K bulbs in your headlights and you’ll be legal so long as they stay on permanently and don’t flash.
powerbulbs.com/blog/2013/09/ … ulbs-legal
Read the regs - headlights are a specific requirement, surprisingly the post has been about additional lamps which has some extra quirks
Just drive the thing, thats what its for
Anyway… I’ve just worked out why we have a driver shortage…
You’re all on here all day everyday knowing best about every single topic except driving trucks…
blue lights this, Carryfast that, the lad only asked a simple question about lights and it turns into 3 pages of utter madness :unamused:
just whack some lights on it and plead temporary insanity if they pull you over for it. :slight_smile: simple
SHUNT1986:
I think you may have missed the point of fora like this [emoji6]
Sent from my SM-G981B using Tapatalk
Acorn:
‘If’ that’s true then there is a problem with the legislation which is ‘intended’ to avoid confusion regarding emergency vehicles on call.It’s obvious that any type of blue light could cause that.
The 4200 K rule is only there to stop headlights turning to a blue colour that’s all.What would be the point if it’s ok to have blue lights so long as not flashing.
I want to know if the cool fade function on my fairy lights counts as flashing lights or not :smiley:
shullbit:
Work sleep and ■■■■ is that all there is to life? [emoji22]
stu675:
shullbit:
Work sleep and [zb] is that all there is to life? [emoji22]
Why is Beer in the swear filter? :wink:
