newmercman:
I’ve never used the clutch with a Fuller, but that ZF box was evil, I had it in a 2300 too, that [zb]stard used to get stuck in 5th and you had to really yank it out, going up the box it was just about possible, but going down I never managed to do it, clutch or no clutch, so I just used to coast to a stop and start again, as it was only a little 2300 it was a bit lethargic on hills, so I quite often ground to halt half way up which was a bit embarassing at timesI don’t mind admitting that the ZF box got the better of me, I had used Fullers, David Browns and even a Foden 12spd, so I think it was more down to the sadistical nature of Ze Germans at ZF rather than my abilities, that’s my story & I’m sticking to it
The Spicer 10spd as fitted to the Roadtrain was also known to be a bit tricky, but I never used one, so can’t say for sure
We had run a fleet of Bedford, Dodge and Leyland/Albions tippers and flats since the early fifties and in 1975 we decided to try DAF. We bought a new F2000 six wheel flat for livestock, mainly running between Tyneside and Manchester and some local work. ZF splitter Gearbox was a right ■■■■■. Alright on a long run but round the doors up and down the box was hard work. Other problems from new were constant cracked alternator brackets, various other electrical problems which we were told was caused by an earth lead not connected properly under the dash and broken piston rings after 6 months. After about 3 years the w/screen wiper assembly dropped out of the front of the cab due to rot.
Got rid of the thing after that.
The Spicer splitter as fitted to the R/train and Constructor (was it 10 or 12 speed ■■) was Ok but going from low to high in top gear was always a crunch
