6 days on 1 day off and then 6 on 2 off
I know this has probably been covered before but I started on Tuesday after having 3 days off. I then worked 6 days and had 1 day off which was Monday. Can I now work another 6 days, Tuesday to Sunday?
Thanks in advance.
Sent from my SM-A326B using Tapatalk
Yes.
But I would recommend you got a copy of the rules to refer to
Or this one I obtained from this forum somewhere.
NB they seem to have different descriptions of how long you have to makeup the reduced weekly rest. 3 weeks or 4 weeks [emoji53]
Lots of other rules that you need to be compliant with 56 hrs driving, 90 hrs driving are they complied with?
The Mexican:
You can definitely work another six days but you may or may not need to start a new 45 hour weekly rest period before 24:00 Sunday, whether or not you can have another reduced weekly rest period after these six days depends on what weekly rest periods you had in the week before last and how many hours your 3 days off was.
tachograph:
The Mexican:
Thanks for your help. I’ll be finishing at 2100 on the Sunday at the latest and then having q full rest.
stu675:
Yes I will make sure I’m under my 90 hours for the fortnight as if I’m getting close to it I’ll ask them to keep me local so it will be less hours and keep me under it. Appreciate your help [emoji106]
tachograph:
The Mexican:
My 3 days off was 84 hours.
The Mexican:
tachograph:
The Mexican:
Not enough to count as back to back regular weekly rest periods then.
I was thinking that if you wanted to have another reduced weekly rest period you could have but now it depends on whether or not you had another regular weekly rest period in the week before last.
Having said that, if you’re planning to have a regular 45 hour weekly rest period at the end of this week it won’t make any difference to you immediately anyway :slight_smile:
tachograph:
The Mexican:
tachograph:
The Mexican:
The week before last was a bit messed up as I done 5 days then had 1 day off worked 1 day had a day off. Long story short I had a reduced rest period. After I do my 6 days this week I will definitely be having a full 45 hour rest minimum.
