newmercman:
Carryfast, your whole argument appears to be that the TL12 should’ve been a Paccar MX13 with a Rolls Royce badge, the Triumph 2.5pi should’ve had the 3.5 V8 so you could have a burn up with a 535i, the BL workforce worked to German standards and Donald Stokes had god like qualities. To that you recently added that AEC should’ve carried on building the Routemaster for another 11yrs.
Well as this all started with the TL12, let’s start there, anecdotes all claim that the TL12 was a flying machine, I’ve never heard of anything problematic about it, the same applies to the T45, the only negative things I’ve heard about that are gearbox related and it’s infamy regarding the whine from the diff, that’s it.
Yes the TL12 was as far as you could go with the basic engine design, but so was the V8 fitted in the completely new 4 series Scania, to raise BHP from 530 to 580 Scania, despite all their experience, knowledge and money had to raise capacity from 14 to 16 litres, nobody had a problem with using the 14 litre engine at the launch of the 4 series, even though the engine design was at the end of it’s life. What’s the difference between that and a T45? Nothing, it’s exactly the same, except Scania had already isolated itself from its money hemorrhaging car division, having off loaded Saab to GM, yet it still launched a completely new range, after 15yrs of the 2/3 series with the same basic engine design as the LB series in 1969 or thereabouts. They used that until 2000ish, so a 30yr lifespan and around 25yrs between the first and last model launches to use the basic engine design. That’s the same timeline as 1950 to 1975/1980.
Now to cover pretty much all of the rest of your argument. Who was in charge while the Mini continued to lose money on every sale? While the arguments about the V8 going into Triumph cars were going on? While the decision to change the wage structure or the colour of the toilet paper or whatever it was that caused the workers to go on strike? Who was in charge when Rover designed and built the, in your mind disastrous, SD1? Who was in charge of BL car, bus and truck divisions while the decisions that led up to it’s eventual catastrophic failure were made?
Here’s a clue, it wasn’t Edwardes.
The TL12 was introduced in 1973 and was foreseeably a pile of useless junk by 1983 so not exactly the Scania V8 gestation and development saga.
Yep it was a flying machine compared to a Gardner 6 XLB in 1973.Borderline v an 8LXB though so even Bewick has to be right occasionally.
Not so good at 38t gross in 1983 though compared to a 290 - ‘340’ RR.
You must have missed the bit that Stokes wanted the Rover V8 put in the Stag but Spen King said doing that would run Rover out of supplies.Although he had no problem supplying MG and Morgan.Webster said it would be a ‘difficult fit’ but he also said no way to the small V8.The old 2.5 6 would do a better job.He at no time said he wouldn’t fit the Rover if King had given it to him.
The Mini you mean the same front wheel drive junk along with 1100 and Allegro that Anorak says saved the firm.
Stokes didn’t have the remit to close down BMC that would have been the NEB and the government owners.The Ryder report also said no for some reason.Stokes being on his way out of the job then so that was also moot in his case.
Just like bringing RR on board in 1976.You know the year that the T45 was signed off and 4 years before its introduction and 1 year after Stokes had stepped down as CEO and 1 year before Edwardes started but who was in the more powerful position as boss of NEB at that point so perfectly situated to bring in RR well in time for its fitment as standard in the T45 at launch covering all needs from 265 to 300 +.
So remind me what did Edwardes do in 1977-82.Other than wrecked Rover and Triumph and closed AEC and gave us the TL12 powered Roadtrain shortly before the foreseeable move to 38t gross.
