Roymondo:
the maoster:
7 posts up ^^^^ Winseer states next day, different vehicle and he gets the same problem.
No, he said he got the “security breach” message and then saw the driving time issue when putting his card in another vehicle - what I referred to as “after-effects”. It wasn’t made clear whether the “security breach” error was seen in different vehicles.
For the avoidance of doubt, the “problem” occurs when the card is ejected (along with the security breach message) leaving the card “not closed”. When it is later inserted into another head unit (any head unit - even one that is working 100% normally) anomalies will crop up.
Mind you, my money is still on it being a defective card.
This has happened to others at the depot as well btw. It doesn’t seem to be based on any particular vehicle, any particular digicard. I am still trying to find out what causes the initial “security breach” upon reaching the end of a duty, switching mode to break as I always do, pressing to eject the card - and THEN getting the “security breach” message as the card gets spat out of the device…
I didn’t make the link to the insertion of the card for the next shift - until on 2 out of 2 occasions that next shift went straight to “card not closed”, bypassing the normal opportunity to make a manual entry, and then booking through the daily rest period - however much that happened to be - as solid driving, rather than other work, POA, or Break… This, despite switching the device on a different vehicle each time to “break” before inserting the card.
I’d like to know if this is happening to anyone else of late - which would suggest that it is an issue with the entire digi software system, as it was on “card self-destruct day” back in 2014, when a load of our digicards came up “card invalid” all of a sudden, which DVLA replaced at no charge - but neglected to give us anything for “free” such as extending the original expiry date on each card… We merely got let off the normal £15 fee for replacing a lost or damaged card. Hardly much of a “freebie” for all the inconvenience thus caused by something which was duly a software issue, and entirely NOT the drivers fault for the thousands of drivers affected on that occasion…
OP - Is this a similar issue to what I have presented details of here? If it were my card, then it wouldn’t be happening to others - but by no means everyone at the depot I’m working at…
Those affected - don’t want to be carrying around reams and reams of digiprintouts forever and ever… So let’s get this sorted by isolating what seems to be a wide-spread problem, and try and nail down the source of this entire issue…
