hope some of you guys can help, can u drive a unit only on a class 2 licence ? im hearing conflicting info that u can, proved fifth wheel is removed, im also hearing that you can drive a unit only, because a class 2 licence means that u can drive anything thats up to 38tons provided its not articulated, confusing or what â– â– ?
Forget Class 2 and class 1, those licences no longer exist, and haven’t done for a long time now. There is one type of licence for driving trucks, over 7.5t, these days and that is a C licence.
If you have a C licence you can drive any truck, and a tractor unit is just a truck.
There is an additional category, E, which allows you to pull trailers with the truck you are driving on a C licence. However a solo tractor unit is obviously not pulling a trailer so you don’t need the E bit.
Coffeeholic:
Forget Class 2 and class 1, those licences no longer exists, and haven’t done for a long time now. There is one type of licence for driving trucks, over 7.5t, these days and that is a C licence.
Simple eh?
its crystal clear now somebody has expained it properly…
postman pat:
Category C,apparently you can drive anything up to 35t. I have just Cat C,and can drive anything up to 35t rigid,as said,and,get this…I can have a trailer,up to 750kg. Yet,my licence does not allow me to tow a trailer on my car
C Vehicles over 3,500 kg, with a trailer up to 750 kg 21*, **
K27:
There is no weight limit for a C licence but there are not many trucks around built with weight limits over 32 tonnes
K27:
Oh yes you can… INFO SOURCE
On a ‘B’ (car) licence you can tow a trailer BUT the combined weight of the vehicle & trailer must not exceed 3.5 tonnes so…
You can use a 2 tonne vehicle to tow a 1.5 tonne trailer
K27:
That limit of 750kgs is for vehicles over 3.5 tonnes if the driver does not have a +E on their licence for the catagory being driven
It is confusing as there are 2 sets of rules - one for vehicles under 3.5 tonnes and another for those over 3.5 tonnes.
Just to add to the mix you can pull a trailer or caravan weighing more than 750k without +E, as long as the combined mam doesn’t exceed 3.5 tonnes and the trailer doesn’t exceed the kerb weight of the towing vehicle. once over 3.5t then +E applies to any trailer over 750kg mam. (i think I got that right)
for the op, had this fifth wheel bollox whilst at DHL shunting, when I was told by a TM I couldn’t take a unit for service, I think that was the same TM who said I didn’t need to put a card in, going to/from workshops .
There is no weight limt, you could drive a 100 tonne crane on C.
MADBAZ:
Yep but the bit in blue is a recommendation and not law
MADBAZ:
Probably an aged TM who was still referring to the old HGV rules where a CLASS 1 HGV was needed for the unit as it was deemed to be part of an artic whether attatched to a trailer or not.
Category B: Vehicles up to 3.5 tonnes MAM and with up to eight passenger seats
Category B vehicles may be coupled with a trailer up to 750kgs MAM (allowing a combined weight up to 4.25 tonnes MAM) or a trailer over 750kgs MAM provided the MAM of the trailer does not exceed the unladen weight of the towing vehicle, and the combination does not exceed 3.5 tonnes MAM.
For example:
a vehicle with an unladen weight of 1.25 tonnes and a MAM of 2 tonnes coupled with a trailer with a MAM of 1.25 tonnes could be driven by the holder of a category B entitlement. This is because the MAM of the combination does not exceed 3.5 tonnes and also the MAM of the trailer does not exceed the unladen weight of the drawing vehicle
Whereas
the same vehicle with an unladen weight of 1.25 tonnes and a MAM of 2 tonnes when coupled with a trailer with a MAM of 1.5 tonnes would fall within category B+E. This is because although the combined weight of the vehicle and trailer is within the 3.5 tonnes MAM limit, the MAM of the trailer is more than the unladen weight of the drawing vehicle
Vehicle manufacturers normally recommend a maximum weight of trailer appropriate to their vehicle. Details can usually be found in the vehicle’s handbook or obtained from car dealerships. The size of the trailer recommended for an average family car with an unladen weight of around 1 tonne would be well within the new category B threshold.
MADBAZ:
An aged TM or indeed someone on TN posting â– â– â– â– â– â– â– â– because neither are correct. You could still drive a unit only on a Class 2 or 3, depending if it was a unit with 2 or 3 axles, in the days before C and C+E licences.
I hadn’t had my license long & on agency, TM mentioned that tractor had to go for service, I volunteered (a drive in a proper truck) but got shot down when he said I couldn’t cos I am class 2, I tried to argue but other drivers stepped in and backed him up with ffth wheel covered/off b/s & I wouldn’t be able to drive bobtail cos its bouncy etc. I was the new guy and knew f/all seemed to be their attitude. They once wouldn’t let me out in a hire Stralis 6x2 rigid with rear steer cos I might find it comes round too quick! I learnt a lot in the few weeks there but managed to separate the mmtm from what was actually correct.
MADBAZ:
That is what I got told many many years ago but as the law changed and I never had to verify it then I simply assumed it was correct - I know - â– â– â– U ME
ROG:
