Hi
how may 15 hour duty days can you do
mon to friday only, without taking a split rest
I WOULD NOT BOTHER ABOUT THIS AS AGAIN I HAVE GOT IT WRONG
Hi
With midweek WEEKLY rests -
6 X 9 hours of reduced daily rest (15 hours shifts) done within one WEEK (Mon 0000 to Sun 2400)
I don’t think more than that can be done
Mon to fri - 4 - tue, wed or thu would be a reduced WEEKLY rest - 3 without the reduced WEEKLY rest
ROG:
6 X 9 hours of reduced daily rest (15 hours shifts) done within one WEEK (Mon 0000 to Sun 2400)I don’t think more than that can be done
no have an other go mate
As there are only 5 lots of 24 hours Mon to Fri and all 5 cannot be 9 hour reduced daily rests then it must be 4 as one of those 24 hours must be a reduced weekly rest.
ROG:
no, work all day mon to friday no rest mid week
3 max then
ROG:
3 max then
no mate try again
i should say that you have got the right number in one of your post but not why
Lost me
ROG:
Lost me
you giving up that easy Rog come on mate have a think
2 but i have no idea about the trick question regarding double manning.
edited for ■■■■ speelin
delboytwo:
Hihow may 15 hour duty days can you do
Ark-Angel:
By “15 hour duty days” I assume you’re including breaks as duty time in which case I think Ark-Angel has the correct idea about double manning, but the answer would be 5 not 2
tachograph:
yes
tachograph:
I think Ark-Angel has the correct idea about double manning, but the answer would be 5 not 2![]()
no, nothing to do with double manning
delboytwo:
how may 15 hour duty days can you do mon to friday only, without taking a split rest
delboytwo:
ROG:
No [ZB] idea then…
i don’t want to give the answer yet, as i would like to see if anyone else can get it
You can do three 15 hour spread-overs between weekly rest periods so Monday to Friday would be three.
With split daily rests the maximum 15 hour spread-overs you can do Monday to Friday is five.
Double manning you could do five 15 hour spread-overs Monday to Friday.
You said no reduced weekly rest period in the week so as far as I can see there are no other alternatives, so I’m saying the answer you’re looking for is 3 because you can do three 15 hour spread-overs between weekly rest periods
tachograph:
Double manning you could do five 15 hour spread-overs Monday to Friday.You said no reduced weekly rest period in the week so as far as I can see there are no other alternatives, so I’m saying the answer you’re looking for is 3 because you can do three 15 hour spread-overs between weekly rest periods
no, keep thinking mate
and it only working mon to fri
Based on your previous attempts at setting these type of questions it would be so much quicker if you just posted the wrong answer you think is correct and then we can explain where you have gone wrong.
5 Days, Monday to Friday
No split rest
No weekly rest within that period
No double manning
Only one possible answer, 3.
Coffeeholic:
Based on your previous attempts at setting these type of questions it would be so much quicker if you just posted the wrong answer you think is correct and then we can explain where you have gone wrong.![]()
PMSL
Coffeeholic:
No split rest
No double manningOnly one possible answer, 3.
no wrong mate and it in the regs you can do more than three mon to fri
tachograph:
Coffeeholic:
PMSL
me too thats a good one
