So today as of now I’ve drove 2hr23m. Can I still split my 1st 45min break into a 15min and a 30mins break?
Thank you
[emoji106]
You can split any driving break as long as you have a minimum 1 min of driving before you start any break
Yes.
Technically you could drive 4 hrs 28 minute have a 15 min break. Drive 1 more minute and then have a 30 minute break.
Thank you chaps. So can I split the 2nd break aswell?
jamieh1990:
Assuming you mean your second 45 minute driving break the answer is yes.
You can split any 45 minute driving break as long as the first part is at-least 15 minutes and the second part is at-least 30 minutes.
tachograph:
jamieh1990:
Thank you chaps. So can I split the 2nd break aswell?Assuming you mean your second 45 minute driving break the answer is yes.
So to confirm if by 2nd you mean the remaining 30 min’s of your first 4.5 hours of driving.
No you cannot split it it has to be 30 minutes.
RayW:
tachograph:
jamieh1990:
The first part of the split break needs to be at least 15 minutes and the second part needs to be at least 30 minutes, you cannot do a 30 and then a 15 .
Legal example for driving time breaks
drive 2.5 hours
break 15 mins
drive 2 hours
break 30 mins
drive 3.5 hours
break 15 mins
drive 1 hour
break 30 mins
Ahhh I don’t know why but I was under the impression you could only split the first 45. That’s made my life alot better now!
Should have posted earlier!
Thank you all
ROG:
Legal example for driving time breaksdrive 2.5 hours
break 15 mins
drive 2 hours
break 30 mins
drive 3.5 hours
break 15 mins
drive 1 hour
break 30 mins
You would not need the second 15 + 30 if the second period driving time did not get to 4.5 hours
You can only do 30 15 if it’s for the wtd, as for split driving brakes 15 followed by a 30 or if you have taken a 30 and wanna split the 2nd break will need to be 30 mins as the first brake will be looked at as a 15 ![]()
Horley:
And there’s no real reason in doing that
jamieh1990:
Thank you
[emoji106]
Indeed you can.
Sent from my Pixel 2 XL using Tapatalk
