I Shift gearbox problems (T range)
Started with a little Gearbox issue today
Some times it’s not selecting a gear while upshifting in even numbers (odds are fine)
Same as when it down shifts doesn’t select even numbers sometimes
Anyone had the same problems? If so what was issue
It’s 470k the box
Scott M:
It’s 470k the box
Possibly whatever the I shift uses instead of the old splitter switch/actuator system.IE no high splits going through ?.
Reboot everything.
Reboot everything.
This^^^^^• battery isolator off, count to 60, re-start, if not then back to Reno.
New box and clutch :frowning: the selector broke for the even gears
Scott M:
how much?
LL79:
Scott M:
how much?
£8.5k - 3 years warranty if done by a dealer…
Scott M:
Only sometimes broke?
Can you operate all gears in manual mode?
Stanley Mitchell:
LL79:
Scott M:
how much?
hmm not cheap…but till yesterday i didn’t know renault has ishift…even i was suspicious…
What could cause this? ishift is supose to be best box out there…
LL79:
Stanley Mitchell:
LL79:
Scott M:
how much?
The I-shift is the best out there [IMO], but like everything, they can go wrong :open_mouth:
I got mine turned round in 24 hours, which was pretty impressive in this day & age, and with the 3 year warranty, I got peace of mind on the box & clutch front going forward… :sunglasses:
LL79:
Scott M:
how much?
Too much :smiley:
dave docwra:
Scott M:
Couldn’t select any even gears in Manuel or auto
Got a box of a t range from a breakers yard what’s done 100k
Sachs clutch and bearing
Dropped it off Monday mid Monday got it back Tuesday afternoon
About 4K in total
