If anyones interested, they can be safely washed at 40 degrees, with no ill effects, mine got done over the weekend and worked ok today, dont know if it removes infringements though ![]()
bugcos:
you have to put it on a 60c super wash to remove infrigments, as they are failry stubborn stains
but putting your digi in a cash machine (try it) using pin code 8945 will wipe any infringments and also re-sets your driving hours to zero
Cruise Control:
bugcos:
If anyones interested, they can be safely washed at 40 degrees, with no ill effects, mine got done over the weekend and worked ok today, dont know if it removes infringements thoughyou have to put it on a 60c super wash to remove infrigments, as they are failry stubborn stains
If only ![]()
Gates:
Cruise Control:
bugcos:
If only
Someones gonna try it though ain’t they
bugcos:
Did you use Softener?
Should have used vanish lol. ![]()
DAFMAD:
Hooray…The correct use of “Should have”…Instead of “Should of”
Boring old git that I am! ![]()
