Ive always thought that if you had a class 2 ,you could drive a unit with the 5th wheel disabled so you cannot pick up a trailer,however recently my TM has been getting class 2 drivers to drive units into London for repairs/collect from London.
Is it legal to do without blocking the 5th wheel??
demonbiker:
This MYTH is sure going strong !!!
The fifth wheel has NOTHING to do with anything regarding the licence required to drive it
demonbiker:
Not anymore.
But it did have something to do with everything regarding the licence required to drive it in the days when you could drive a 38 tonne 2+3 drawbar outfit with a class 3 but you needed a class 1 to drive a solo tractor unit without it’s fifth wheel being removed.Unless ROG can show me otherwise.
its no different to driving a car with a tow bar, as going with that train of thought that would be illegal also just because you could go and attach a trailer heavier than 750g
forget the HGV classes -they have gone - it is now LGV C1, C & C+E
A unit is a C - fifth wheel being on or off has nowt to do with it
Not anymore.
I cannot find anything relating to the old HGV regulations - I reckon they have been withdrawn from the Govt sites as they are out of date - so cannot comment on what was…
psv8:
think what rog is saying anyone who is able to drive a 7.5ton can drive a tractor unit providing weight does not exxed 7.5ton .
NOT CORRECT
A C1 (max 7.5 tonne) licence would NOT in 99.9999999% of cases be enough to drive an artic unit because the PLATED WEIGHT of the unit is well over 7.5 tonnes
Cruise Control: YOU CAN LEGALLY DRIVE A “UNIT” ON A CLASS 2 (C) LICENCE AS IT’S A RIGID TRUCK REGARDLESS AS WHETHER IT HAS A FIFTH WHEEL COUPLING OR NOT.
EDIT: was doing my peice of artwork while ROG posted his
