Anyone out there give me the true height of the bridge on the A461 between the walsall ring-road and heading out too the A5…Are the signs wrong
many txs jmk.
The sign on the A461 says 14.6, but i go under regular running at 14.9. If you are higher than that if you are approaching walsall from the A5 end when you get to rushall on the 461 turn left up the side of the mcdonalds follow for about 2 miles and you will come to some lights, turn right straight over 2 islands and your back on the 461, missing out the bridge. hope this helps ya fella.
The sign is correct but the bridge is an arch and the 14’.6 refers to the outer edges so it is possible to go through higher but of course this would be illegal wether your truck fitted or not.
