Was talking to a driver who got pulled over and he’d got it all ratcheted, but not to be defeated he was told to make sure in future the ratchets were positioned on the near side so that if they needed adjusting he wouldn’t be in the flow of traffic. Tbf it’s not something I’d thought about but it does make sense what he said.
This was something I learned from an old school driver a few years ago when he seen my load of steel pipes with the ratchets on the o/s. Like you, I never even thought of it till he pointed it out to me. I now always put the ratchets on the n/s now.
That was until I got a new trailer last week. It’s got those internal straps on a bungee system that needs a ratchet on both sides to secure them, so now I have no option to have ratchets on the o/s.[emoji35]
I’ve always aimed to get dollies, dogs and ratchets on the nearside. Just seemed to make sense to me…
Tris:
Sounds like rubbish to me ,didn’t you know they don’t need adjusting ,not even on fertiliser !!!
Tris:
Advisory but not compulsory.
Just to be an arse (out of character I know
) I would have told them to ■■■■ off and mind their own business as I was loaded for Holland ![]()
Punchy Dan:
Tris:
Was talking to a driver who got pulled over and he’d got it all ratcheted, but not to be defeated he was told to make sure in future the ratchets were positioned on the near side so that if they needed adjusting he wouldn’t be in the flow of traffic. Tbf it’s not something I’d thought about but it does make sense what he said.Sounds like rubbish to me ,didn’t you know they don’t need adjusting ,not even on fertiliser !!!
You’ve not hauled timber then ?
Can see the safety side of it with traffic etc but I’ve always put then O/S and can’t seem to get out of the habit.
Feels strange if I have to go to N/S to undo them.
I always strap to what the load layout dictates
blue estate:
Punchy Dan:
Tris:
Or steel? Or big bags of aggregate? Or pallets of 25kg bags?
dcgpx:
Can see the safety side of it with traffic etc but I’ve always put then O/S and can’t seem to get out of the habit.Feels strange if I have to go to N/S to undo them.
Nothing to do with having to carry them further then. ![]()
I only haul steel and try to get all ratchets on the n/s but you have to strap the load so that it is secure. Also, any one who thinks that straps won’t need adjusting/tightening on route shouldn’t be using ratchet straps ![]()
The Sarge:
blue estate:
Punchy Dan:
Tris:
Or cable drums etc etc etc
chunk:
Depends what you’re securing surely. If it’s seed it’ll need tightening before I get out the yard ( waste of time ratcheting tbh - internals are better but dvsa wouldn’t agree ), likewise timber shifts if it’s not packed tight and loaded tight, but certain things I know they won’t need adjusting.
What do us car transporter lads do…only strap one half of a car down?
Tris:
chunk:
I only haul steel and try to get all ratchets on the n/s but you have to strap the load so that it is secure. Also, any one who thinks that straps won’t need adjusting/tightening on route shouldn’t be using ratchet strapsDepends what you’re securing surely. If it’s seed it’ll need tightening before I get out the yard, likewise timber shifts if it’s not packed tight and loaded tight, but certain things I know they won’t need adjusting.
I was told that as the trailer twists going round corners and over uneven ground so the load can move slightly and settle meaning that the tension on straps can be lost. I regularly check them and usually have a couple that have loosened!
chunk:
I was always told steel needed chains and not to use straps? Your pix only show you using straps? Or is it because you have the upright supports in?
Or was it a myth I was being told.
blue estate:
The Sarge:
blue estate:
Tris:
or HAY, need to retighten that every 3 bends, 3 bumps or 3 miles, whichever occurs first - LOL
blue estate:
The Sarge:
blue estate:
Punchy Dan:
Sounds like rubbish to me ,didn’t you know they don’t need adjusting ,not even on fertiliser !!!You’ve not hauled timber then ?
I think Dans comment just MAY have been tongue in cheek?? ![]()
Tris:
So if I load in Europe, what would you suggest be the best/safest side of the trailer that I should place the ratchets ?
